DaveyBoy
- Oct 13, 2004
- Fitchburg Mass
- lacroixmotorsports.tripod.com
What Belt is the best to use on the RX-1 The yamaha belt or a other
yamahajunkie
YAMAHA for sure
Turk
Tech Advisor
8dn-00 worx great!!!
impalapower
Yamaha belt. If you go with a Gates, they have a 1 year warranty.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
OEM Yamaha
DaveyBoy
- Oct 13, 2004
- Fitchburg Mass
Kewl thanks guys i will keep with it then i got 2600 outta my 1st one
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
Yamaha
I tried a Gates on my Warrior and it did not hold up too long!
OEM all the way
I tried a Gates on my Warrior and it did not hold up too long!OEM all the way
WarriorWithin
I only got 2000km's out of my OEM Belt and then the threads started coming out of it. Anyone else had this problem? I was thinking of getting an Ultimax 3 belt to replace it has anyone used this belt?
impalapower
Who knows, maybe you just had a bad belt.
Buckeye
- Lakes Region, NH
Stock belt is the best.
after 5000 miles i still have the 2 yamaha belts i started out with.
DaveyBoy
- Oct 13, 2004
- Fitchburg Mass
Nice snappy I`m from Mass too where r u I`m in Fitchburg
A
Anonymous
WarriorWithin said:I was thinking of getting an Ultimax 3 belt to replace it has anyone used this belt?
I have one. I use it for drag racing because you lose about 5 MPH on the top end using one. The take off is snappier though because the belt is a little more softer than OEM and grabs better.
Snorover
- Apr 15, 2003
- Kittery/Fayette,Maine
- 2017 Viper
I got 6700 miles on the OEM belt and it's still got more to go.
muskrat
Belt
Yamaha belt for sure. I tried a Dayco III last year and grenaded it after crossing open water. Belt only had 200 miles on it. Put the original 8dn on and it's still working. Not planning on crossing water again, wasn't planning on it the first time but when you're the only Yamaha and all these Jet Skies, a.k.a. REVS do it , well what could I do.
MM
MM
