Blue Me
Here we go again for my dumb
!! I am purchasing the Freddie's ECP kit and am gonna clutch it and am considering using the Heavy Hitters. Any better ideas? The sled will be stock other than if I get the rest of the money together I will go to a 136" tunnel but for now she is staying 121. Dalton, Thunder Shift, HH, WTF!!!
Help me out guy's I don't know exactly what I'm doing here. I have no other friends that have this sled. You guy's are my only hope for help.
Help me out guy's I don't know exactly what I'm doing here. I have no other friends that have this sled. You guy's are my only hope for help.Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Heavy Hitters all the way! Call Matt at the Speedshop. www.thespeedshop1.com
black john
clutch
i pesonaly have had god luck with daltion,s others have had good results with hh setups
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
I agree. Heavy Hitters
Blue Me
Clutch kit
So what will the setup be for HH as a shorty for strong out of the hole and killer midrange pull with the ECP kit?? Any suggestions or are these things so easy that I'll figure it out in no time at all next winter?? :itchy:
sledheadgeorge
- Apr 28, 2003
Sorry I can't help you with that one. I've got a turbo on mine. If you change your ecp kit and get a turbo I would be more than happy to help you out, as many other members on this forum will. The HH are easy to adjust. Good luck
Cubby's RX-1
- Nov 14, 2003
- Willoughby, Ohio
- www.cubbyscustoms.com
Yea, I am going to switch to heavy hitters from the heel clickers I have now. Why? Because Matt has tested and tested to try and find just the right clutching for the ECP kit, and I cant seem to get the heel clicker to work properly with the ECP kit because when it comes to clutching I am a dunderhead. Polishing= no problem, Clutching=big problem.-----Cubby
Rick
There is no doubt in my mind, get your kit from the Speed Shop. Matt has his act together his is by far the best set up out there.
