DaveRX1
I havent had a sled with a rear limiter strap in 25 years, what will shortening it do for the ride??
(This is not about the front arm limiter strap)
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
increase ski pressure...and decrease the travel in the front of the skid..
Nytro Fx
why would you want too?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
correction my comments were for the front strap....what are you referring to ...the transfer rods? they increase transfer (rock back and squat) and decrease the point of coupling the front ant rear arms (decreased ride quality)...they also will lessen ski pressure at times...
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
The Nytro shorties have a strap in the rear as well, no transfer rods. I'm curious to see the responses as well.
DaveRX1
Grimm said:The Nytro shorties have a strap in the rear as well, no transfer rods. I'm curious to see the responses as well.
This is what I am looking for (rear strap info) This applies to Nytro short tracks only.
gormleyflyer2002
adds forward/front coupling.......biggest thing you'll notice is the front wont hunt or dart as bad when you let of the gas or brake into corners.....sleds is a little less pitchy.
I have mine pulled one hole from stock.
sleddingfarmer
gormleyflyer2002 said:adds forward/front coupling.......biggest thing you'll notice is the front wont hunt or dart as bad when you let of the gas or brake into corners.....sleds is a little less pitchy.
Any negatives to tightening it one hole?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
in effect it sounds like a transfer rod but with a strap
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I was looking at it earlier today and was wondering the same. It looks like if you pull the strap tighter it will collapse the rear suspension giving it less travel. I'm not sure how this effects handling but I would think it would take away from the ride.
gormleyflyer2002
sleddingfarmer said:gormleyflyer2002 said:adds forward/front coupling.......biggest thing you'll notice is the front wont hunt or dart as bad when you let of the gas or brake into corners.....sleds is a little less pitchy.
none at all, just way easier to drive it into corners at higher speeds. Bring a 10mm wrench and a ratchet on a test ride and adjust it trailside on a trail you can test or repeat a section so you can notice the difference.
My shocks have been revalved so no worries about the weak azz valving and massive transfer.
