apex yooper
I've been hearing a lot about push on corners. I think this expression is new. What exactly is push.
YamiSmurf
Push is when you're trying to turn left or right but your sled still wants to go straight.
YS
YS
richierich
- Apr 23, 2003
- Greenville,WI
- 08 Apex LTX
yep same as sliding or drifting thru the corner
MADDOG24
Push ,understeer and tight are the same thing. Too much hookup in rear, not enough in front.sled won't turn. i.e weight transfer, ski pressure, carbides and even keel design on skis. I'll take a slightly loose sled over a tight sled any day.
Red2003
richierich said:yep same as sliding or drifting thru the corner
Sliding or drifting implies the rear or entire sled is losing grip through the corner, a push means only the front is losing grip.
Rent days of thunder - Tom gets a quick lesson on the diff between tight and loose. Loose is fast but hard to control back end wants to pass the front. Tight, a push drives the front straight ahead no matter what steering imput is given.
buddah
- Apr 14, 2003
- Wetmore, MI
- '17 Sidewinder B-TX LE
What do you care??? You got no sled to ride anyway........
apex yooper
I'm just curious about all the ill handling sleds. I've got stock skis, idlers, and carbides, and everything is perfect.
What Happened? Jaybuddah2 said:What do you care??? You got no sled to ride anyway........![]()
