jakob
- May 30, 2014
- pat hauck apex
currently i have one of the 4 special edition pat hauck sleds. It has mpi suppercharger pipes clutching low comp pistons rods studs. It is currently 240 hp what all do i need to bump it up to about 300 with a pulley swap. I was told i need injectors a different fuel pump and oviasly some race gas. I was just currious on what all i need to make some big power.
sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
Call Matt @ mpi. Then call ulmer racing. Of you are at 240 I am assuming you already have a larger fuel pump. There is an upgrade in the mpi kit from the stage one to the two. 11-12lbs is max I believe on a stage one kit.
