Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
I run amsoil in the following:
04 Lincoln LS
02 Saturn SC-2
00 Fleetwood Motorhome Ford V-10
97 Ford F-150
68 Vette
04 Yamaha FZ-1 (same engine as in our sleds)
04 WR450
01 Yamaha Wolverine quad
Onan Generator in the motorhome
Emergency Generator for the House
05 Simplicity Garden Tractor w/23 HP Kohler
Honda rear tine tiller
Go Cart with a Honda engine
I will run it in my RTX once I get about 500 miles on her.
Dang, looking at that list now I see why I'm an amsoil prefered customer
04 Lincoln LS
02 Saturn SC-2
97 Ford F-150
68 Vette
04 WR450
Iknow all the benifits of running synthetic lubes.but how many miles are you going to do this season? and are you going to leave that oil unchanged if you only do 1-2000 miles this season? and as far as oil breaking down thats usually from hi temps.if your in the middle of nowhere your probably not going to find your brand of oil if you need any.welterracer said:snappy said:why waste your money on synthetic?
Because you can go more miles on a oil change and you have more protection because the syn oil doesnt break down as rapidly!
I am using 5W20 Mobile 1 in my apex gt..
I would totally agree that syn is better after break-in for engine longevity, especially at the rpm these things run. The one thing that has me curious is that I have heard from several different people that syn does not offer as good of corrosion protection as semi-syn. Some of this info is from dealers who claim that fogging two strokes is more important than ever since most people are running full syn injection oil. Anybody have thoughts on this?
I plan on keeping my new 07 Attak for a LONG time, and I'm more worried about corrosion during storage than I am about wearing it out during riding.
Why wouldn't Yamaha recommend full syn?
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
The corrosion resistance issue I believe was true of early synthetics ie 70's, but not true any longer. Their are some oil industry people on the site maybe they can confirm. I am 99 % sure this was discussed and it is no longer a problem.
Yamadoo
Yamadoo
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
Corosion protection is now on par with petroleum based oils. The only reason semi sythetics are around is cost. Some synthetic is better than none, 100% is better than some.
icedog
Does anyone use Mobil 1 0w40?? in their Apex's
Sled Dog
snappy said:Iknow all the benifits of running synthetic lubes.but how many miles are you going to do this season? and are you going to leave that oil unchanged if you only do 1-2000 miles this season? and as far as oil breaking down thats usually from hi temps.if your in the middle of nowhere your probably not going to find your brand of oil if you need any.welterracer said:snappy said:why waste your money on synthetic?
That is what we are saying with this oil there wont be a break down because of the oil.
Sled Dog
MightyRTX said:Me too, great stuffZR800EFI said:I'm running the Amsoil 4-stroke synthetic.
I am too best stuff you can buy IMHO.
Sled Dog
Do you think because we are running an oil other than what Yamaha wants us to run if we ever have a warranty issue with these engines would they try to get out of covering it? Anyone know for sure?
craze1cars
Anything's possible...direct quote (shortened) out of the YES contract which I just got in the mail a couple days ago:
EXCLUSION #3: If a particular breakdown is caused by...maintenance other than is shown in the...owners manual...breakdown will not be covered."
I don't know if changing oil brands causing a problem, but if you show 'em copies of receipts that document you're running a 0W40 or 5W30 in an engine that they clearly specify 0W30 for? I dunno. What does the manual actually recommend foO oil...do they say Yamalube 0W30 "or equivalant"? Dot hey give alternate weights that are acceptable? or does it just say Yamalube 0W30? Mine's not handy at the moment.
I'm not sure if burdon of proof on such a failure would be on them or on you, but I figure why screw with it and risk it? Anything's possible IMO...Unfortunately my crystal ball is in the shop at the moment and they're denying my warranty to fix it because I didn't break it in properly...
SledFreak
- Feb 7, 2005
- Ontario. Canada
What's the weight on that? 0W?ZR800EFI said:I'm running the Amsoil 4-stroke synthetic.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
Yamaha can not void the warranty for you using a different brand of oil. You will not, I repeat; you will not have an engine failure because of the type of oil you use. Unless you do something stupid like fill your crankcase with something like 2-stroke oil. Then you wouldn't deserve to have it fixed under warranty anyway
Any effects on the engine caused by different types (petro vs. synthetic) of oil will not be seen for long term. The only short term effect you may notice would be something like easier starting with synthetic in extreme temperatures.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
0W-40SledFreak said:What's the weight on that? 0W?ZR800EFI said:I'm running the Amsoil 4-stroke synthetic.
SledFreak
- Feb 7, 2005
- Ontario. Canada
That actually could of been a contriuting factor to why your sled was so fast. Lighter weight and less friction...MightyRTX said:Me too, great stuffZR800EFI said:I'm running the Amsoil 4-stroke synthetic.
