Skydog
Guys what RPM to spin her at? Is the stock clutching ok?
Thank you Skydog
Thank you Skydog
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Turk has said the stock clutching is pretty much spot on after you get 1,000 miles on it.
I consider him a darn good source of info on that topic.
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
Sky, with stock clutching you should run low 10's and gain RPM to about 10,500 or a bit more near topend. Most clutch kit's like to run more RPM, 10,500 to 10,800 on top and some say 11,000 on top is just fine but keep it off the limiter (11,200). Are you retiering the 03 ? kviper
Skydog
Thank you guys!
Are you retiering the 03?? Yes i am selling her. It has been my best sled to date! But i have a chance to get a 07 i am going to jump on it! If the Wife says ok i must snag a 07!!! HAHAH
Skydog
Skydog
Turk
Tech Advisor
Sky; after 1000 miles stock clutching is pretty well bang on. 10,600 rpm is the sweet spot with stock weights. With aftermarkets I gotta run higher rpm,s to get the same top end. You can play around with helix/spring combos in the secondary for some small gains.
