TLM
- Jul 19, 2014
- Hortonville, WI
- 2012 Nytro xtx, oft relocate, oilite bushings, comfort clutch, tunnel block, tailight relocate, cr10EK plugs, copper donuts, tuner skis, Grizz Tracks gusset kit. Excell x wheels. Mo-Flow console vent and curved vents.
On a2007 apex attak, what should the engine rpm max out at when at wide open throttle? Also getting codes 22 and 84. Any help would be appreciated....
TLM
- Jul 19, 2014
- Hortonville, WI
also what should the stock primary weights be and what color would the stock spring be in the primary?
Click on the 2007 and scroll down: http://www.totallyamaha.com/snowmobiles/AAATuning Chart/Specs.htm
If you take 5 min to look around you will find all kinds of info in the FAQ sections in each forum or in the TY Tech link in the menu bar....
For the code 22. Make sure the sensor on the airbox on the clutch side is plugged in. Forgot to plug mine in after an oil change and it threw code 22.
Check the free play of the throttle cable for code 84.
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
I believe they are supposed to tach out at 10,800 rpm's.
Mine is about 10,800 to 11,000 depending on conditions
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
The sweet spot on all my apexs was 10,800 to 11,000 depending on clutching I had.
