ridgerunner1
I will be using a Shaper Bar with Pilot Skis this season and I was wondering what size folks have been running. I was thinking 6". My Attack has 108 studs and my riding style is slightly aggressive. Thanks for the input.
LJ 452
Go 7.5", it's not a big difference. Mostly more wear protection.
vmaxcrazy
I have an 06 Attak with 168 studs in the middle of the track. I have the 6.9 pilots and use the 6" shapers in the middle and 4" woody's in the outside. Sled turns well just sitting on it through the corners at moderate speeds. When the pace picks up I have to lean hard to the inside as the ski's bite so hard I get bad inside ski lift. I'm going to work on the inside ski lift this year. So, to answer your question, 6" is more than enough.
whitedust1
- Jan 10, 2008
- Waterford ,WI
- 2012 Apex XTX
Square tips don't fit round so ask if square or round. If they send you square grind them down. Common with doo skis & shaper bars.
Yamahammer485
9"!
Also, square the whole length!
