Iceman57
I'm changing my lower gear to a 40 tooth and want to go with synthetic oil in the chain case. Can anyone tell me what weight I should go with??
n2oiroc
75w90. make sure you use gear lube, not amsoil chaincase lube. it is like water!
Iceman57
Is Mobil 1 ok to use in the chain case?
chaincase oil
mrance111 yes mobil is fine.
zipclean
Used Amsoil for 25 years and not one chain case problem,or leak if sealed properly.Runs way cooler.
Zipclean, are you currently using Amsoil chaincase oil in your yamaha? And how long have you been using it? I just changed my track and installed Amsoil in the chaincase. I thought it looked thin comparied to what came out.
n2oiroc
yamaha recommends 75w90 gear lube. would you put strait 10w oil in the engine?
APEX 21
- Jul 21, 2005
- Pardeeville, Wis Northwoods & UP
4,089 miles on my Apex ER with Amsoil, 7,000 miles on my RX-1. I've had 0 chaincase problems.
Guys any oil would work in a chaincase! Full synthetic is the way to go if you want better lubrication and a cooler running chaincase. Synthetic all the way.
I did a viscosity test with the Amsoil Chaincase Lube and Mobile One synthetic 75-90 gear lube and they are too close to worry about.
bgbytoys
- Jan 25, 2006
- upstate ny
- www.troycitygarage.com
yamaha reccomends a hypoid oil, but we have used a 80/90 non hypoid no problem.
Yamahammer485
What does Hypoid mean anyways?
My 2002 Honda 350 fourtrax 4x4 requires this oil in the rear final gear and front diff. Iv been using a sythetic oil in it and it works like a champ, never had a problem, but I think its non-hypoid.
bgbytoys
- Jan 25, 2006
- upstate ny
hypoid is for high presseure areas like your differential gears.
SledderSteve
- Apr 23, 2003
- Orange County California
- Rental
http://yarchive.net/car/hypoid_gear_oil.htmlYamahammer485 said:What does Hypoid mean anyways?
- 21K
