JDMCRX
- Dec 13, 2005
- OTTAWA, ONTARIO CANDADA
- www.jbauto.ca
Just got a 04 rx-1 warrior friend bought a 03 RX-1 whats the big differences. Ive looked so far i foundout the 04 is a bit lighter??/
Anyone thanks
Anyone thanks
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
Different front springs.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Longer links between swaybar and A-arm. Upper A-arm is aluminium. Front springs are 1.9 kg straight rate. Coil assembly are different from '03.
JDMCRX
- Dec 13, 2005
- www.jbauto.ca
Anyone else i heard its like 28 to 34 lbs lighter?
WarriorBeads
- Dec 4, 2005
- Peterborough, Ontario, Canada
- 2004 Rx Warrior
Unless I missunderstand, your 04 is a rx Warrior???? If so, then it'll be considerably heavier than the 03 rx-1.
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
Obviously, the warrior has a longer track, wider running boards with grip edges, different clutch/gear calibrations, and is standard with reverse. But the real difference is the Warrior needs much less work to enjoy and fetches approx. $1000 - $1500.00 more when you go to sell it, and about $500 - $800 more at trade-in time. Unfortunately, if you can't find someone who isn't in-tune with the progression of Yamaha's 4-stroke plan, you'll get even less.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
JDMCRX - Taking about the RX-1 shorties, there was not a significant weigth reduction between model years '03 and '04. '04 warrior was the first year of that model.
