im1dragon
- Jan 8, 2004
What are the big deferent between 03 RX-1 and 04 warrior?
thanks. :roll:
thanks. :roll:
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
15 inchesim1dragon said:What are the big deferent between 03 RX-1 and 04 warrior?
thanks. :roll:
First off, the Warrior has all of the upgrades for 04.
Main difference between a Warrior and RX-1 is the length of the skid. The Warrior also has a clicker shock in the rear, lower gears as well as electric start as standard equipment.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Me thinks you mean reverse as Standard equipment.
Both have electric start standard.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
Oops
Thanks Riceburner, that is what I meant.
im1dragon
- Jan 8, 2004
i can get new 04 worrior for 8000 or new 03 rx-1 for 6500. :roll:
what would you get and why? :roll:
thanks
thanks
Buckeye
- Lakes Region, NH
which model?
Which 03 model?
I would probably get the 04, because it is a year newer so there is $1000 of the price once you own one. The upgrades are worth more than the $500 balance. They say the longer skid rides better in the rough stuff, but i haven't riden one. Now if the 03 was $6000.......
Which 03 model?
im1dragon
- Jan 8, 2004
bros thanks for the reply.
:shock: Buckeye you make good sense and it is RX-1.
please help making my decision. :roll:
thanks.
thanks.
welterracer
im1dragon said:i can get new 04 worrior for 8000 or new 03 rx-1 for 6500. :roll:
thanks
You cannot get the clicker shock on any sled but the Warrior... WHICH I MIGHT ADD RIDES F*CKIN AWSOME!!! The longer skid and hightly adjustable suspenson is the best yamaha has to date...
I will never own another sled without reverse ,,,, it rocks!!
Buckeye
- Lakes Region, NH
Which model?
I meant which model RX-1 was it? For example does it have a reverse? the Warrior does. If it doesn't, that is another factor. What about color? Which do you like better? For the $1500 the 04 is a better buy. Remember it will be a used snowmobile once you own it which is a quick $2000 depreciation at least. Most of that is eaten already on the 03. It will be worth 5500 at the end of the season. The 04 will be worth 6500 maybe. At least that would be here in NH.
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
Get the Warrior!
Better skid
better track
better sway Bar
better sway links
better hand warmers
better seat
better springs up front
better shocks in the rear
Better Upper A arms
Better clutching
Better reduction Gears
Better Drive gears (geared for more low end)
Non skid edge on the tunnel
Imagine how much it would cost to update any of this on the 03 which you most likely would do.
The Warrior is more valuable because #1 it's a Warrior and #2 it's an 04.
And a much better ride because it's 136 inches with that great clicker shock! Everyone I know that has an RX-1 complains about the ride, not one Warrior owner I know has a complaint on their ride.
Better skid
better track
better sway Bar
better sway links
better hand warmers
better seat
Better Upper A arms
Better clutching
Boston RX1
Mighty RX-1 said:15 inchesim1dragon said:What are the big deferent between 03 RX-1 and 04 warrior?
thanks. :roll:![]()
The Rx1 does not come standard with reverse. The RX1 ER does. Do not buy this sled without reverse. I think I would go with the Warrior. Many new improvements and all of the bugs worked out. Bugs may be a little strong, I'll stick to many improvements.
