SharkAttak
ride it now until the end of the season, then take care of the maintenance in the summer
dooboy600
Are there any performance gains to the 3 cylinder 120 engines using the cr10ek plugs?
Do they help gas mileage as well?
SharkAttak
dooboy600 said:Are there any performance gains to the 3 cylinder 120 engines using the cr10ek plugs?
i would say no for the cr10ek's on the 3-bangers, try the cr9ek's
scottymac
I thought one of the mags did a test on the cr10ek plug and found no evidence of any horse power gain. It is just a mith
SharkAttak
scottymac said:I thought one of the mags did a test on the cr10ek plug and found no evidence of any horse power gain. It is just a mith
no mith, try running against one with the cr10ek's and you keep you stock ones , you'll be ordering them quickly
vice108
It's been dyno proven over and over.
scottymac
Why would yamaha not put these in from stock if they make their sleds run that much better, is there a chance that the can harm or lower the life of the engine? You think they would run the best possible plugs for the best performance.
SharkAttak
scottymac said:Why would yamaha not put these in from stock if they make their sleds run that much better, is there a chance that the can harm or lower the life of the engine? You think they would run the best possible plugs for the best performance.
they have them in the phazer & nytro
