347strokin
I've got an 07 Apex MTX SE. It has never had a tail light or rack on it. I'm buying a stock tail light for my sled but there are no wires running to the back of my machine.
Can anyone tell me where your tail ight wires originate and run from?
Also what color are these wires?
I have a couple connectors that arent hooked up sitting above where your right foot would be.
mud99
Check under the seat, near the front, on the right hand side.
347strokin
mud99 said:Check under the seat, near the front, on the right hand side.
I've got everything off...gas tank, seat etc and I have no wiring there. I need to find out where the wiring is further upstream. Thanks.
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
347strokin
Crewchief47 said:Looks like it goes into the main harness about the same height as the reverse lever, #21.
Thanks a lot. Any idea what colors the wires are? I have two empty connectors there and I don't have reverse so I'm not sure which one it is.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Should be a triangle shapped one.
347strokin
kinger said:Should be a triangle shapped one.
Yep, sure was. Thanks.
