Where is my battery?
It is under the air box. Pretty easy to get at after you remove the air box.....................Brian
If your going as far as taking the battery out you may want to change the oil while your at it. Your oil filter is right under your battery. Make sure the air box boots is put back onto the carbs correctly very important and it could be missed causing you lots of grief.
