lrioux
where is the best place to install the a/f gauge sensor on the 09 nytro? I have a mpi stage 1 on the way from hartman inc and ordered my aem boost & afr digital gauges from jegs. just wondering where i will be placing the sensor for most accurate readings..
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Install it several inches in front of the muffler (under the heat shield that the seat sits over). I will try to take a picture tomorrow and post it for you once.
lrioux
a pic would be very descriptive..thanks
- Apr 17, 2003
- Menno, SD
- Menno, SD
Allen you spent some time cutting backers ~ letting all the light weight secrets out.
