furg69
Where do you take the 12volt switched power for the gauges ? I would like them to power up when the dash does. Also where do the boost gauge sensor hose go on mpi 180 kits I don't see a nipple anywhere. Thanks for any help guys
Brown wire(I think its brown) from ignition provides a fused 12V source. Pull back grey outer cover and tap into it. Its easiest to remove key switch from dash and splice into wire with it out.
furg69
I'm guessing that should be fine to power up my koso LCD gauge and my AeM wide band as these should only draw minimal amperage
