Daryl1
I have an '06 RTX, I bought used. I'm wondering if there is a way to tell which spring I have in the mono. I believe it must be a heavier spring as I have it as soft as possible on the cam settings, and preload dial, limiter strap 1 from stock, I weigh about 190 lbs -no gear. Suspension is slightly stiff, but, problem is not much ski presure with 50 lbs in the floats, -steering seems to light. Any ways, my question is, can i measure wire diam., or free length to identify this spring? I'll ride it through the winter, maybe find a stock spring in the off season.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Try 70-75 psi on the floats and perhaps more aggressive runners.
