Which wear bars for '11 apex se? Length?
mr. shide
tipton, IN
Have a stock 11 apex se. Going to put 102 studs inthe track. Which wear bars/length are you all using? I had bergstrom triple on my 06 gt. but may just go with woodys or stud boy shapers?
I love love love my snow trackers best thing i ever did to my sled next to buying it.
used 6 in shaper bars with dads 2012, make sure alignment is good no matter what you use.
Love my Bergstroms, at this point I wouldn't think of using anything but.
X2. The best thing you can add to an Apex!!
Pffft. SnowTrackers.. Is there anything else??
Went from 4" carbides to doolies and thot "These are great" but then was introduced to Bergstromms. Wow what a great product until I tried SnowTrackers.
Best carbide I've had for all types of driving. Have converted all my Apex/Attak riding buddies to SnowTrackers believers and users.
X 4 SnoTrackers
Make sure you get the right ones !!!!
Specify Semi Aggressive for a 2011 Apex !!!!!
What's skis are you running on your attak with the snowtrackers?
X2 best thing you can put on an Apex.
I will be Snowtrack hers affect top end? I assume you run the entire kit with the wear bar plus the U-shaped piece correct?
Riceburner said:
X 4 SnoTrackers
They changed the design for the '11s and up so now you can run the Aggressives.
Using Aggresssives from a '10 on a '11 will give you undesirable steering.
I have my buddy's '12 SE set up with Aggressives and 102 picks.
Handles very well in the twisties and on the long lake runs.
Yes use the entire kit. The U-shaped piece is the key to elimnate the darting.
Have not noticed any loss of top end. Then again I'm trail riding not bracket racing.
