IDA rather b sledding
I got the new to me sleds out yesterday. I installed a used white knuckle exhaust on one machine, primarily for the weight savings. The info said 2 db louder. First off, no gripe to the fella I got it from. Greg gave me a fair price and we had a excellent transaction. It seems this system has an awful resonance at about 7500. The actual loudness is not bad. I am thinking to wrap the exterior, or something. Any suggestions? Otherwise I am going back to stock. The other sled I bought has a homemade under tunnel exhaust, 2 glass packs with WR 250 baffles. It sounds great.
bdm
I had the EXACT same problem with resonance at 8,000 rpm, although it was with my glasspack instead of a White knuckle. Added a CC insert and that took care of the resonance.
http://store.summitracing.com/egnsearch ... toview=sku
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
- '03 RX-1 Mountain LE
IDA rather b sledding said:I got the new to me sleds out yesterday. I installed a used white knuckle exhaust on one machine, primarily for the weight savings. The info said 2 db louder. First off, no gripe to the fella I got it from. Greg gave me a fair price and we had a excellent transaction. It seems this system has an awful resonance at about 7500. The actual loudness is not bad. I am thinking to wrap the exterior, or something. Any suggestions? Otherwise I am going back to stock. The other sled I bought has a homemade under tunnel exhaust, 2 glass packs with WR 250 baffles. It sounds great.
Does it sound similar to this? http://media.putfile.com/BlgsRX-1mtn-w-boost
This is a Modded QC-1 Exhaust from Whiteknuckle (cut out H-pipe and added stock exhasut x-pipe) with an MPI Stage ! SC running 5lbs boost.
Jim
Frostbite
Oh yes, I remember the 7,500 RPm resonnance. It about splits your head if you stay there for any length of time. I solved it by going to an under tunnel exhaust. There's more power, a weight savings and even some ear savings to be had from the mod.
Best of luck
Frosty
Best of luck
Frosty
I decided to try packing insulation around the can under the heat shield. I also installed the Apex exhaust turnouts. Much better overall. The wife says it's okay now.
rage man
keep your eye on the welds my white knucke broke last year wasnt to impreased
