White Panels????
Confused?
Syracuse, NY
so i need white panels and i was wondering wat my options are? I play a lot of lax and i know paint will chip but what about die? As a lax player i die a lot of heads and they go through hell and back with me. Die holds up longer than my head will lol so is it possible to die the panels?
if you prep the panels properly and prime and use a good quality paint and clear coat your panels should hold up pretty well. just make sure you mix the stuff in the ppaint that allows it to flex with the panels. i'm not sure what its called but the professionals use it. Ask shaddow44, he painted his panels white and it looks as if they are holding up really well
Painted panels hold up fine, proper prep and flex agent in the paint is all that is required. I'm going on my 3rd season and my panels look fine.
