flmcut1
i heard alot about white spring with 60 degree . is this a good clutching setup for apex with 23 tooth gear. ty
Kaz
It seems the 136" Attak setup is a very good setup for the 121" track, white spring at 60 (3-3) with the 23T top gear.
Do a search and you find lots advice on clutch setups. From what I have read on here they come pretty good out of the box. The 23t gear seems to be the ticket.
Kaz
Kaz
Laubry
- Aug 26, 2006
- WATERFORD MI
- sr viper
- YAHOO
- larryaubry@ymail.com
I have a apex er 121"stock
put i do not have lots of $$$$
to put in it.
so i need to now 23t gear the best for $$$
and if the white spring too.
need setup info. for white spring.
to put in it.
Kaz
Laubry said:I have a apex er 121"stock
to put in it.
The Yamaha white spring is set to 60 degrees (3-3), put the 23t gear in it and you have the same clutch setup that came with the 136" Attak that everyone raves about.
PS do a search on the 23t gear
Kaz
Laubry
- Aug 26, 2006
- WATERFORD MI
- sr viper
- YAHOO
need part #
on white spring and 23T
rxwhopper
in my opinion the white spring did nothing, tried a back to back in the apex. just gear it
mshabaz
- Aug 16, 2006
flmcut 1, looks like you did the 23t swap, what differences did you notice???better holeshole, more or less top end???
flmcut1 said:i heard alot about white spring with 60 degree . is this a good clutching setup for apex with 23 tooth gear. ty
apex yooper
spring
Thanks Hooper,
That's the way to do it. Not try the change different days with different conditions and imagine that you can FEEL the difference.
Thanks Hooper,
