DenaliDoo
My wife would like a wider stance on her Phazer MTX and I noticed spacers on the skis. Is this designed like other sleds to be able to move the spacers and widen the stance about 2''?
If so, any tips or just pull the pin, nut, then shaft move things and put it back together?
Yes those bushings are there to adjust your stance.Pull the boldt out that holdthe ski on.Then put both spacers on the outside of the spindle and boldt the ski back on.
DenaliDoo
That is what I thought. Thanks for the help. I wanted to get this done before our last rides of the season.
No problem.It's easy to do.You could even do it out riding for the day.have someone hold the sled on it's side or pull up next to a snowbank and tip it against it so your ski is off the ground and take the boldt out and adjust how ever you like it.
- 7K
