Bodacious
From the brochuers, it looks like the Apex Mnt uses a 16" track, does anyone know if the Attak tunnel is the same and, or will accept a 16" wide track?
LazyBastard
It will fit, but you may need to make some modifications; narrower drop brackets, shorten the bolts from the chaincase, etc.
Bodacious
Thanks!
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
I understand the 16" wide track will help with the floating or lack of floating your attak does,but word of caution you may want to chat with some mountain boys before you go thru this mod. as the wider track may be some of there problems with ripping there tracks up and there tunnel coming apart,and you might even give someone a call at yamaha to see if they recommend you do this,it would really suck if ya spent all this time and hard work/money to find out it works sweet but down fall is track only lasts two rides... just a thought.Bodacious said:Thanks!
![Tsr :rocks: :rocks:](/styles/default/xenforo/smilies/tsr.gif)
Jonny Rocket
- Colville, Washington
- 2008 MXC boosted Nitro
There has been several posts over in the mountain section on this. Here is one of them:
http://www.ty4stroke.com/viewtopic.php?t=18698
