russellrox
- Oct 2, 2011
Will a 16" wide track fit on my 2010 Mtx Nytro 162, or
Will a 16" wide track fit on my nytro, need a quick replacement for the season.
..SNAKEBIT..
running one on mine 162x16x2.5
out in the snowies now and seems to be working well, had to turn some bolts around, grind rivets and rework rear drop brackets
emr333
I've got a 162x16x2.5 Camo extreme on mine, just put spacers inbetween the drop brackets and the skid and it seems to be working. Had to grind the rivets and bolts down at the front of the tunnel.
smithereenpsycho
I went to a 174x16x2.5 CE this season, ordered new drop brackets to run a 16 wide through CR Racing in Kelowna BC, they also have a bolt kit for $20 specifically to go 16", just had to grind down the rivits. I've put on 1300 Miles this season, the only time I can hear it rub is when sidehilling on harder packed snow but that is expected with the length of skid.
lund
I run a 174x16x2.5 on mine and no issues. I did find that the bigger track effected the handling abit, not as easy. But the pro is great floatation and hookup for the fat heavy beast.
- 6K
