apexgtcx
- Aug 28, 2005
- tughill
- yamahamotors.com
just wut the title says will a firecat track fit under my phazer with just putting some bigger idler wheeles in it
sniperviper
no it wont fit!
Swiss Sledder
- Apr 18, 2003
- www.mi5.gov.uk
Rode a Phazer with a 1.5" track. It had great hook up so that might be a better option.
wayfastkev
Why wont a firecat track work? Its a little narrower. You might have to shave off a quarter of a inch from each side of the wheel spacers and add extensions. I know of someone on hardcore sledder who has done it and I am seriously think of doing mine instead of the 121" freeride track. You could go a easy 128" and wont have to alter the rear tunnel.
yes it will fit with some rail extension's
You should check out what Mars did to his. He has the 128" track. looks real sweet.
Mars
Yup, no idea on how it hooks up though, gots no snow here....
http://www.ty4stroke.com/viewtopic.php?t=43734
mnf7sp
my F7 hooked up awsome. I want to put 128 x 1.375" on my phazer but I was going to do the math and see how big of rear wheel I would need!
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
To go from a 128" from a 121" you would need 10 tooth drivers and 10" rear wheels. This setup will not work in the trail as under full compression of the rear suspension the track will hit the tunnel in the rear. Run a set of 3.5" rail extensions and you can use the stock axle & wheel setup. I have extensions if you're interested.
Mars
Srxspec said:To go from a 128" from a 121" you would need 10 tooth drivers and 10" rear wheels. This setup will not work in the trail as under full compression of the rear suspension the track will hit the tunnel in the rear. Run a set of 3.5" rail extensions and you can use the stock axle & wheel setup. I have extensions if you're interested.
That will work exept the rear bushings (if you want to run 2 outer wheels) will need to be milled down .250 each side, due to the 13.5" track. The front wheels (by the coil spring mount) will need to be removed, or somehow modified to fit. (you would have to re-design the spring mount, making it .25" narrower.) You can't just mill .250" off of it cause the wheel will conctact the mount.
skidoochris
I want to buy a used 121 hacksaw
one guys junk is anothers treasure
