Will Apex/Attack fuel injection fit on RX motor?
73Satellite
I installed my RX motor (complete) into my Apex chassis because the Apex motor overheat and is shot. I want to install the Apex fuel injection, wire harness, and everything else onto the RX engine. WILL THIS WORK? The only real difference besides a slightly different engine casing and that there is a sensor on the front center of the apex motor that is not on the rx motor. What sensor is this and can a get away without plugging it in. If I cannot run the apex fuel injection and wire harness on the rx motor in my apex chassis I will run all RX carbs, wire harness, brains, etc. I just need to make the airbox and plastic fit. Anyway, has anyone done this or know if it will work?
Thanks for all the input. Its appreciated.
John
hen I put the Apex motor in my RX last summer I was told It would work so I would think you can go the other way. I ran it with the fuel injection and changed all of the electronics over to ge away from the choke and better throttle response.
The sensor is the oil pressure switch. I would think I can bypass it and run the fuel injection. I believe I would have to run the fuel injection to get all the other parts to fit for airbox, headlight, plastic, etc. Its already saved a lot in other parts....shocks, oil tank, crankcase cover, etc. We'll see though.
