Four Stroker
I want to replace don't care if Ihave to pay its worth the time savings from having to go to the dealer everytime wheel goes crap.
TurboJamie
Yes we installed a set the bearing is a little wider and requires a longer bolt but they do fit. They also can retain the doo caps to cover the bolt and finish the sled off a little more.
APEXER1
a7m266d said:Yes we installed a set the bearing is a little wider and requires a longer bolt but they do fit. They also can retain the doo caps to cover the bolt and finish the sled off a little more.
Have you checked the posistion of the wheels on the back inside idelers when you put your doo wheels on, because if there not right they will hit the lugs and they will get chewed up and alot of people that took your advice and spent the money for them are not going to be happy.
Then you will be eating CROW!
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
are you guys only putting these wheels on in place of the 2 middles that blow?? Or are you replacing all 6?
SledFreak
- Feb 7, 2005
- Ontario. Canada
So, do they fit or not, without making modifications to anything.
87gtNOS
- Nov 30, 2005
- Toronto
and....IMO, this sled needs MORE wheels....let off the gas and it near stops!! It doesn't freewheel very easily.
BURMAD69
87gtNOS
- Nov 30, 2005
- Toronto
BURMAD69 said:4 Strokes dont free wheel, Been riding one since the 03s came out.
I don't see why it shouldn't...I can roll the tcat in the driveway with one hand pushing..the APEX needs me to pull and strain!! This is not right...where is the restriction?
87gtNOS
- Nov 30, 2005
- Toronto
the engine brakes...but turn it off and roll it...now what's holding it back???
SledFreak
- Feb 7, 2005
- Ontario. Canada
Yes, I have heard, there is alot of friction in the chassis, but where is it?
87gtNOS
- Nov 30, 2005
- Toronto
I am gonna find it.SledFreak said:Yes, I have heard, there is alot of friction in the chassis, but where is it?
QCRider
Fully clip your track, or use the SLP anti wear pads in the closed windows and it moves a lot more easily. I think it's the closed window on the hyfax...
87gtNOS
- Nov 30, 2005
- Toronto
QCRider said:Fully clip your track, or use the SLP anti wear pads in the closed windows and it moves a lot more easily. I think it's the closed window on the hyfax...
That's sure what it feels like!!
cameljockey
im going to a fully clipped ripsaw. i only have 500 miles on and my hyfax are shot. the wheels bad didnt help much either.
STORM-CHASER
I just fully clipped my vector and I can tell you it will help, now when I on the track stand the track will creap alittle, never did before. I have not have had snow to ride it on but I am sure it will pick up some top end. The clips only weigh 3 lbs. I have a post on it in the rs page
- 15K
