rangermike14
- Feb 19, 2015
- Byron Center, MI
- 2006 Apex
1998 SRX 700
Nice! I'd like to ride one of those pre studded tracks. I like the idea. Hope it does well for u.
He is saying he also has a 1.5" Intense track with tunnel protectors removed and that it's easy to remove them but you get covered in shavings when you still out the old rivets. He is not running studs.
.????? Trying to make sence of what you wrote!
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
In with ya HABS!! Cursing at those front rivets with the die grinder, covered in aluminum!! Im running a 1.75 with stock drivers. Love the hook up, especially with boost!
Rich Kay
- Mar 29, 2006
- SE MI. Howell
- Yamaha apex rtx
Got Ya!In with ya HABS!! Cursing at those front rivets with the die grinder, covered in aluminum!! Im running a 1.75 with stock drivers. Love the hook up, especially with boost!
Johnny Goggles
- Jan 21, 2018
- Northern NY
- 2007 Apex
Dumb question. What is an extrovert driver? I am going to 144" on my '06 Apex. Got a rocking deal on a take off track, so I bought it.You can put rail extension on with no issues. You need to run extrovert drivers so the track cam be run looser. I just extended min from 121" to 136" and lots of others have as well. Go longer with it!
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
Rather than the drivers grabbing the rubber nubs on the back of the track, plastic teeth on the drivers run through the holes on the track. In other words, all windows would need to be open.
Good luck!
Good luck!
