Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
I was curious because last year after doing some testing I noticed that my Warrior runs better when it is cooler
After the season was over I added a TEMPERATURE gauge so this winter I could more closely monitor it!
If a valve was added to shut off the coolant to the carb manifold on those warmer days above 0 degrees, would it help performance?
LazyBastard
Not likely and certainly not measurably. The big performance changer that comes with temperature is AIR temperature - colder air is more dense, therefore more goes into the engine, therefore you get more power. Also with temperature you get different SNOW conditions (this is the REALLY big one)- warmer snow is stickier, therefore SLOWER.
The amount of heat that will be absorbed by the air going through your carbs is totally insignificant. The heat in the carbs can have some slight effect on fuel going through - again, cold gas is dense gas, but this would just cause your engine to run more rich, BUT, not nearly as much more rich than what the colder air would DEMAND (which means NO DIFFERENCE).
What a coolant shutoff valve will do is make warm starting easier - the gas in a hot carb will expand and push up your jets, causing your engine to slightly flood, which is why you need to crack the throttle to start it when its WARM.
yamahajunkie
already have done it to my 05 warrior, i think it will, from what i have read on this forum
yamahajunkie
boy sounds like it will just start better bob. i should have waited a minute or 2. Posted: Thu Oct 07, 2004 1:28 am Post subject: lb
Bob Miller
- Apr 19, 2003
- New Milford CT
I posted this once before.
One day in January in Canada I was staying at REAL MASSE and I was out all day riding, the sled was warmed up ! It was about 15 degrees at the time. I got out on the lake (it's 1/2 mile run) and I let the Warrior rip
I did about several runs and I saw 104 on the speedo.
So I tried something :shock: I rode into some deep snow and rode around in it and let the heat exchangers feel that nice cool snow.
I then got back out onto the lake and nailed it
I then saw 112 on the speedo.
It was a coool experience!!!!!
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Bob Miller said:I rode into some deep snow and rode around in it and let the heat exchangers feel that nice cool snow.
I then got back out onto the lake and nailed itI then saw 112 on the speedo.
I would put more stock in the fact that your hyfax got colder too.
yamahajunkie
still a little easy mod, that will help your sled start better when warm. time and thoughts spent on the sled, than in the bar.
LazyBastard
For that speed change; as mighty said, the sliders are the big thing for fresh snow - they were probably melting and sticky before the snow. Asides from that, you may have changed the overall ENGINE temperature.
Lots of time when running in marginal snow conditions, its necessary to find patches of snow to drive through in order to keep moving. You can tell if its your sliders by slowing down - if it slows down unusually fast, it means that you've got some extra resistance in the back. If you kept running in the marginal snow conditions, you would have noticed your speed gradually drop as your sliders started to melt again.
Bob Miller
- Apr 19, 2003
- New Milford CT
That day the snow conditions where good on the lake!
I believe it had something to do with engine, coolant temperature.
RX1 Yooper
Lazy bastard,
What you said makes sense. One question I have is how can the gas push up the jets, if the float bowls are vented?
I agree with your answer, but can remember all the SRX and Viper owners recommending turning the heaters off, for better performance in warm weather. Were they wrong?
