Will this riser work for an apex?
riser
yes that one will work will take a little modding to make it fit but it does work...i have one already modded for you i can sell you pm me if interested....as for bolts i used the longer ones from a phazer mountaint....reuse your original caps and stack the riser under the factory one...
If you want it to look decent, buy another stock riser, then cut it down to your desired height.
Remember, with the angle of the steering post, the farther you move the bars up, the farther they move back.
Unless you use an articulating riser system.
Well, the ROX riser, unless used on the TOP of the stock one, will not allow you to use the chrome trim piece above the tank shroud.
I understand why he would be hesitant, I stewed a long time deciding how I was gonna accomplish my goal of moving the bars forward and still being able to use the chrome piece. PowerMadd came out with this adaptor (the middle piece)the month before I changed it, so it worked out....
We (Muffin Works) have some awesome riser kits available for the Apex. They are fully polished billet aluminum pivoting risers available in three different heights. Our pivoting adapter is also machined to fit perfectly with the stock chrome trim ring, and allows you to keep the chrome trim ring installed.
Check us out!
Thanks for posting, gade...A friend was interested in some alum parts, and I told him there was a place up by Marathon, but I couldn't remember the name..........thanks
RTX Dude....how did you like the 3.5? Is it high enough to stand up from time to time, or did you just add it to stop the slouching over a bit.
If I recall correctly when I spoke to you at Johnsons, you were about the same height as me. Im 6'2 barefoot so with the yammi boots probably closer to 6'4
