snowdawg
I could use a little help on a RX 1 carb. There are 3 points to plug the carbs in 1 you have the two wires with male and female ends 2 the black plug in top side of the carbs 3 the white plug that runs bottom side of the carbs. My question is the white on the bottom side wasn't plug in ? Any one know that them wires do? I was getting very bad hesitations while taking off and with no snow no way of seeing if I fixed the problem. Thanks
grader
the two bullet plugs are tors wires, that leaves either tps or carb heaters. without going out and looking at my sled im guessing its the carb heaters. they only come on at startup then warm coolant takes over.
