DTJ
- Mar 31, 2016
- Brainerd, MN
- 2023 Yamaha Sidewinder XTX
2017 Yamaha Sidewinder BTX
Anybody have any ideas on this one. 2014 XTX, it started last year and has gotten progressively worse. Only when starting cold so far in temps ranging from -15F to 25F I have to give it a little throttle or it dies and I have to hold it until it fully warms up. Once it warms up it runs normal. I have checked TPS in diagnostics open and full throttle with bars straight and turned all the way and it comes back 0% without throttle and 100% full throttle. I have the latest flash. I have an 8" handlebar riser and the adjustment is maxed out, so I unhooked the cable from the throttle to make sure the cable isn't to tight and it still does it. I have tried taking the belt off to make sure it's not my deflection set to tight. I'm still on the original battery and have noticed it is really turning over pretty slow. Is there any chance a weak battery could be causing it not to idle when cold? Any thoughts would be appreciated.
