WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
It's not the relays or the TORS but the sled will not idle. If I give it throttle it will start and run. As soon as I let off it dies. If I don't touch the throttle it will fire then die, then fire then die. I'm thinking the IAC valve. Ran great then wouldn't run in the morning. Any thoughts?
Mototown
- Sep 11, 2018
- Apex 40 th
Get the sled up to temp , take it for a short low speed ride , shut off for 10 min . Should go away . Or put in heated garage
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
That's what I was thinking. IAC must be iced up. I'll try that tomorrow. No heated garage. At a hotel in Vermont. Rode the Nytro today cause I didn't feel like messing with it. I forgot how much fun that wheelie monster is in tight trails.Get the sled up to temp , take it for a short low speed ride , shut off for 10 min . Should go away . Or put in heated garage
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
Must have been the IAC valve iced up. I ran it around in some powder right before shutting it off to cool it down after coming into town. Must have pulled in a bunch of moisture then it went to 0 over night. I kept it running till it got to 190, shut it down, let it sit 10 minutes then it was fine. Ran great all day. I did have the fuel pump relay freeze on it and my dad's viper this morning though. Someone needs to make a solid state relay for this thing.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Had the same thing happen .Must have been the IAC valve iced up. I ran it around in some powder right before shutting it off to cool it down after coming into town. Must have pulled in a bunch of moisture then it went to 0 over night. I kept it running till it got to 190, shut it down, let it sit 10 minutes then it was fine. Ran great all day. I did have the fuel pump relay freeze on it and my dad's viper this morning though. Someone needs to make a solid state relay for this thing.
Don't even need to let it sit 10 mins..
Just get it to running temp and shut it off , and it should start right up , as good as new.
Only happened once , and it was after a very short ride of less than a half mile , where the sled never got up to temp , and then shut off , and sat outside all night .
It wasn't even very cold the next morning , just the moisture I guess .
Mototown
- Sep 11, 2018
- Apex 40 th
Same thing happened to me , just freaks u out in the morning when u are ready to leave the cottage and it won't idle. When you are already on high alert because of the arctic cat factor ...lolMust have been the IAC valve iced up. I ran it around in some powder right before shutting it off to cool it down after coming into town. Must have pulled in a bunch of moisture then it went to 0 over night. I kept it running till it got to 190, shut it down, let it sit 10 minutes then it was fine. Ran great all day. I did have the fuel pump relay freeze on it and my dad's viper this morning though. Someone needs to make a solid state relay for this thing.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Seeing this on a buddies Viper right now. Thing is terrible on cold starts in AM.
