bowtietr83
'18 winder will not idle. Won't start unless you Crack the throttle while cranking and then it will start but you need throttle input to keep it running.
Did the same thing last year first ride of the year, probably -20f out. Today it's high teens. Last year it cleaned up after awhile and was fine the rest of the week. Guessing it will do the same this time as well but wondering what the root cause is? Ran fine the couple other times I had it out this year. I did just put a new battery in it but it started ip fine directly after that.
Any ideas?
Any ideas?
Derek Fosbury
- Jan 18, 2021
2022 Sidewinder S-TX GT
2023 AC T-Cat EPS w/ATAC
- Sledding Location - Fenelon Falls, ON
Do you use gas stabilizer while storing? I know my machines have always been very sensitive to stale gas. My 2021 Venture started terribly until I got through the first tank of dealer gas.
bowtietr83
Yes, usually a full tank with some seafoam in it.
Kuzzy
- Dec 6, 2020
- saskatchewan
2020 yamaha sidewinder xtx se
2022 STX GT
2017 King Cat M9000
Spark plugs? There are times when mine starts on only 2 cylinders, then after a bit all 3 kick in. usually happens after driving them from the garage to the trailer, then then riding in the trailer to launch area.
bowtietr83
Changed plugs last year, probably 800 miles since then. It's just weird that it clears up and is then fine for a few days. Seems like something electronic.
Confused
- Oct 12, 2008
- Mound, MN
'21 Sidewinder LTX SE
'23 MXZ Blizzard 850 ETEC
'88 SnoScoot
Mine did the same thing 2nd start of the year. Started fine once in the heated garage. I replaced the spark plugs and no issues since. I do new plugs every year in all of my machines. They are cheap.
mario750
I had about 200 miles on plugs when mine did same thing… I’ve changed plugs and it runs normally. Although my sled is tuned and I’m running Torco octane booster, maybe that contributed to short life span of spark plugs, I’m changing them every year regardless mileage.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Mine does NOT die at idle, but does do weird things... I changed the plugs on mine last year and gapped to .20. I am running 270SS from Hurricane, if that matters. This year, it starts right away, but the odd time if its not fully warmed up or if I shut it off it gives me a bit of a fuss to start. It tries to fire and just sputters, but it wont. Takes 2-3 cracks at it and then it starts. I dont touch the throttle at all. But when it does, it fires no problem on all 3 cylinders. Fires up no problem when cold too. Plus runs strong when its running. It just weird!
aquaticlaker
- Feb 21, 2009
- Green Lake WI
- SIDEWINDER L‑TX LE 50TH
- Green Lake Wi
aquaticlaker
- Feb 21, 2009
- Green Lake WI
- Green Lake Wi
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Have you tried gapping the plugs back to factory spec? Mine is acting the same way after gapping the plugs to the tighter gap like you.Mine does NOT die at idle, but does do weird things... I changed the plugs on mine last year and gapped to .20. I am running 270SS from Hurricane, if that matters. This year, it starts right away, but the odd time if its not fully warmed up or if I shut it off it gives me a bit of a fuss to start. It tries to fire and just sputters, but it wont. Takes 2-3 cracks at it and then it starts. I dont touch the throttle at all. But when it does, it fires no problem on all 3 cylinders. Fires up no problem when cold too. Plus runs strong when its running. It just weird!
SledFreak
- Feb 7, 2005
- Ontario. Canada
No, I was actually thinking of putting them back to spec or at least maybe halfway. ie..23 or .24. I think stock was like .28-30?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
When I spoke with Dave I asked him about plug gap and he said the tunes were built using the factory plug gap.
SledFreak
- Feb 7, 2005
- Ontario. Canada
That's different, because TD says to change the gap on the bigger tunes. I run 240-270SS as the 300 is just hard to find 93 Octane in order for it to run safe. I think when I change them in the spring that I will leave them stock or at least make sure they are gapped to Yamaha spec.When I spoke with Dave I asked him about plug gap and he said the tunes were built using the factory plug gap.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Next time out in the garage I am going to gap mine back to factory spec. Hope is runs better down low then.
