Savard
- Dec 14, 2011
it goes in between the reverse gears, the smaller gears that touch the big bottom one. if you pull those two smaller gears apart you will see a small hole that it sits in. not sure what its for but i noticed it when it fell out of mine during track swap. part 59 in the picture.
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
No, its not one of the springs between the reverse gears. Way too big.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Looks like an exhaust valve spring from a an old 2 smoke or check your "reverse handle rod" there's a similar dampening spring on that.
Did a buddy throw this spring into your bolt bin to have some fun with you?
