MadMax
I just got off the yammie home page.. Did some serious looking over everything. I was wondering if the cool piggy back shock on the nytro would fit and maybe help the ride on my vector? I noticed it has a 20 click adjustment that I don't have. Hmmmmmmm.. If it's valved to agressive then I'm not interested at all.. I guess the only way of knowing is to go to a show and bounce around on one..
.MM.
.MM.milljk
MM, Should work on your Vector. I have Ohlins on mine and the rear absorber is a clicker shock with 21 clicks of compression adjustment. Kind of tight to get your hand in their to make changes to the compression but does a good job. Never rode sled with stock KYB shocks so I can't compare but really like the dependability/adjustability of the Ohlins. New shock should be similar to Ohlins. Might want to price them out. I got the dealer to trade me my original shocks and then it was $250/unit for the upgrade.
MadMax
Thanks. I bet they won't be giving them away. :ORC MM.
321.00 in the max performnce book for the adjustable shock for a vector.
Tork
MadMax said:I just got off the yammie home page.. Did some serious looking over everything. I was wondering if the cool piggy back shock on the nytro would fit and maybe help the ride on my vector? I noticed it has a 20 click adjustment that I don't have. Hmmmmmmm.. If it's valved to agressive then I'm not interested at all.. I guess the only way of knowing is to go to a show and bounce around on one...MM.
As a vector owner, I'd keep what you got. The Nytro was very harsh for this 185lb rider. This suspension is made to withstand the rigors of crashing down after catching big air and not trail comfort. The Fox float shocks, those I really liked.
timebomb
mrsled posted that the piggybacks are going to be available for 05 vectors, rage, warrior and rx1
