clutch
I just took off my 27in Dirt Devils and installed a set of stock tires that I just bought. Those heavy tires sure suck up a lot of power. I couldn't believe the difference.
The reason I changed is because we are going to Arizona and will be visiting the Glamis Dunes area. I had visions of getting stuck in the soft sand with the Dirt Devils. I also thought the big tires would make the engine work a lot harder too. My quad looks kind of puny with the stock tires on it but I am sure it will work a lot better for where we are going. The big ones will go back on when we return home.
I know I have done this....you dont realize all the power those big tires can kill!!
