yamalube
- Jan 23, 2010
- Happy Valley Goose Bay ,labrador
do you guys think i should gear down my xtx if i put a 13/4 back country the dealer says nobut my friend says yes, is it really nessary
Costello210
gearing
I went to a 20 tooth top gear and left the 39 bottom in mine when i went to the back country. I thought it worked real well, pulled hard out of the corners and sill had good top end. However, i never ran it with the 21/39. I'd gear down.
MOUNTY
Its just fine stock gearing.
stopdropanroll
- Oct 8, 2008
- Fall River WI
- www.styleonecustommotoring.com
20/39
Turk
Tech Advisor
If i was putting on a back country I would definately gear down to a 20 top tooth.
Sask Attak
I geared mine down last tuesday. I love it.
09xtx
- Feb 27, 2009
I have an 09 xtx with 1.75" backcountry. I went to 8 tooth extrovert drivers and it works great
Turk
Tech Advisor
8 tooth drivers will drop ya 2 teeth on top & also mess up your shallow approach angle. Not recommended.
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
- 2025 SRX
2018 High Country 9000
2001 SRX 700
I geared down 1 tooth also, for 20/39. I took the first and only ride of this year last week, on loose snow, and rpm's seems good with the stock clutching, so i think it couldnt be better.
