extreman1
anybody have a cooler off a mtx that u want to sell? not the front one looking for the side tunnel one with the hoses. my s/c nytro runs hot! also does any body have the mountain preformance heat exchanger with track studded? wondering about stud clearance? Thanks for any info
86blackt
Just installed my MPI heat exchangers. I cut out the existing tunnel protectors. They install on an angle, so doesn't look like the studs will hit....I will post after I get everything together. I bought my kit off of here, and it was missing a couple parts, so I have had to make a couple orders to MPI. Did you have to do any grinding for top pulley to fit?
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
I have MPI"s long tunnel coolers, now for 3 years. No problems. I also did the radiator delete and it still runs very cool. And got alot of heat out from under the hood that way.
86blackt
I left my radiator in. I ride in marginal snow most of the time
