sgilbert
oh ya, go to the gym
Doc04viper-s
- Dec 19, 2010
Well I did the set up that was aan the sticky. WOW! HUGE improvement. I also widened the skis. I could maybe tighten the center spring a tad bit more. If you have not done this set up to your xtx you should. Thanks guys.
Next Lake effect bar risers & tank bag. That will be it for this year.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Doc04viper-s said:Well I did the set up that was aan the sticky. WOW! HUGE improvement. I also widened the skis. I could maybe tighten the center spring a tad bit more. If you have not done this set up to your xtx you should. Thanks guys.
UMMM AHEM
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
How did you widen the skis?
You meant widen the ski stance right? Just keep an eye out for excessive wear at the ski mounts due to the offset spacers.
Doc04viper-s
- Dec 19, 2010
That is correct the ski stance.
GT03235
my nytro was horrible when new the handling was scary lol after much tweeking i now have it perfect. i found that once the rear is set thats a leave alone item, but the front i alter on every ride as varying snow conditions make a huge differance.
mike3577
- Oct 18, 2009
- auburn hills,mi
- 09 nytro xtx, 8 inch slydog powederhounds, mbrp silencer, ulmer racing clutching, fast track studs,cr10ek sparkplugs,
hit the flipper and the steering gets very easy
GT03235
Thats awesome lol
