Tophat
- Feb 24, 2024
- Deloraine, Manitoba
- Apex XTX
I have a 2011 apex xtx that rides really rough. I have all setting on lightest setting. I have installed star kit. I was told that springs form a Nytro may help. Any advice or suggestions would be appreciated.
blown apex
something is wrong i have 4 xtx and they ride great they were very hard stock with a lot of frictionI have a 2011 apex xtx that rides really rough. I have all setting on lightest setting. I have installed star kit. I was told that springs form a Nytro may help. Any advice or suggestions would be appreciated.
call robert at star he did my shocks also
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
I have 2 Apex XTX's with the star kit and they ride smoooth as melted butter! something is wrong with your install.
in my 11 xtx i run the 09 nitro xtx springs without the star kit. stock ones on it would not move. what i would do is grab a buddy and check that when you are sitting on the sled that the rear transfer is at 40/60 or 50/50 on the transfer assembly. i prefer the 40/60 as it allows for snow build up in the tunnel. i just replaced the springs on my 11 as they where weak after 15000 mi of abuse i mean riding.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2017 Sidewinder LTX SE - TD Power Trail, CAI, 3" Super Quiet
2012 RS Vector
2006 Apex GT
- Middleville, MI
There is no transfer setting at the rear arm when you have the Star kit installed. Transfer is controlled by the limiter straps and preload on the center shock.in my 11 xtx i run the 09 nitro xtx springs without the star kit. stock ones on it would not move. what i would do is grab a buddy and check that when you are sitting on the sled that the rear transfer is at 40/60 or 50/50 on the transfer assembly. i prefer the 40/60 as it allows for snow build up in the tunnel. i just replaced the springs on my 11 as they where weak after 15000 mi of abuse i mean riding.
Tophat
- Feb 24, 2024
- Apex XTX
I just finished putting on a set of springs from a 09 nytro springs. The ride is considerably better but the back end sure sits low. I appreciate any of the input to this issue . I'm for a few days riding in Idaho so here is hoping all goes well.There is no transfer setting at the rear arm when you have the Star kit installed. Transfer is controlled by the limiter straps and preload on the center shock.
