Nice Rumble
Does anyone make a relocation kit for the taillight so there is room for a bag, rack or fuel pack? Anyone have any pics?
sleddingfarmer
I do not believe anyone makes a kit. But it is simple to do. Simply remove the reflector that is right above your bumper. Then take your tail light off and take it apart. The screws for mounting your tail light will line up with the holes from the reflector rivets. I just drilled a hole so the wires for the tail light could go under the tunnel. might have to extend the wires...not sure on the xtx.
There are pictures online here somewhere.
sleddingfarmer
check this out, did it a little different then me, but some pics so you get the idea.
http://www.ty4stroke.com/viewtopic.php? ... tail+light
more pictures...most of these guys did alot better job than I did, I was in a real hurry!
this thread will tell you which wire is which, if you end up doing any wiring.
MaineiacZ06
