ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
I would be very interested in seeing pics of the tunnel heat exchange system also. I have a serious ice problem....when running through slush and freezing in the tunnel and extension.
I would also like to see pictures of the heat exchangers under tunnel to keep the icing down. If that is the ticket then I would probably go under tunnel exhaust also.
zx4ever
- Apr 14, 2011
- Northern BC canada
- 08 nytro ty4stroke customized
Unddertunnel
Come on bamboo let's see some pics. I'm going to try some tin and play around with a cover over the muffler. But I would like to see what else would work
s1d3w1nd3r1480
I am thinking of trying the mpi tunnel cooler kit and rad delete kit in the summer to solve this problem but am kinda waiting to see if I decide to turbo or not. If I boost I think half the cooler will get in the way of my charge tube
Tyloooor
RX1MPete said:I would be very interested in seeing pics of the tunnel heat exchange system also. I have a serious ice problem....when running through slush and freezing in the tunnel and extension.
try a tunnel block off kit??
