yamaha attak hauck exhaust need help
zigzag420
manitoba, canada
hi i have an 07 yamaha attak with hauck exhaust and other then that it is completly stock. since installing the exhaust after the sled is warmed up it only idles at about 1200 rpm and if you hammer on the gas to hard it will stall. the end of my tail pipes are black and if you rub your finger in there it comes out black, you can see the odd drop of gas comming down the pipes and if you hold the throtle wide open for awhile when you let off you will get the odd crackle and if i am playing in the powder and fall of it will die only sometimes tho and then the warning light will flash untill i turn the key off then on again. i dont know if i am running to lean or to rich or if it will do any damage to my sled, do i need a fuel programer? and also i have put on 100 miles like this should i continue riding it?
http://www.youtube.com/watch?v=KGye16lu0Ys
