Likely lost prime to the oil pump. I've never had this issue, but remember others having this happen. I'll move your post to the Nytro forum where you'll get more advice,
If I understand you correctly the sled is running fine but you have a code. If that is the case I'd disconnect the battery for a minute to see if the code goes away. Welcome to TY.
