yamahaboy701
Very good idea from Yamaha!
Everything you need in one box, no price yet but usually kits are cheaper then buying everything separate.
http://www.yamaha-motor.com/sport/appar ... etail.aspx
Part Number:
LUB-SMBCG-KT-00
Part Number:
LUB-SMBCG-KT-00
arteeex
Everything you need in one box...not really. Unless the box contains someone to do the work for me, there's at least one thing missing.
yamahaboy701
arteeex said:Everything you need in one box...not really. Unless the box contains someone to do the work for me, there's at least one thing missing.
Very ture!
I seen this as yamaha maybe showing customers that you don't need to be a mechanic to change the oil. Kinda like a push to do it yourself.
Apex809
Yeah,so they can say you never changed your oil or you did it wrong.Thats why it blew up! Then they will not warranty any motor work. I have heard this.
Alatalo
- Jan 11, 2005
yamahaboy701 said:Very good idea from Yamaha!
Also, I see no sealing washers for the crankcase and oil tank bolts.
According to the workshop manual, you are supposed to use new washers every time you change the oil...
