scar
Just installed my yamaheater plug and play with boost that I bought from Rock.Grips get real hot real quick.Can't wait till it gets real cold to try these babies out.Thanks Rock.Highly recommend this mod unless you like cold hands.
I got a set for my sled, then my buddies got sets for there sled and the next things you know 5 sets later we all had warm hands. They worked great!
Great product.
Is it a simple install? I bought a used one w no instructions
scar
Real easy,you can get picture by picture install on this site
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
Excellent product and excellent customer service!
scar said:Real easy,you can get picture by picture install on this site![]()
I searched but didn't see them I'll have to dig deeper
Found in the FAQ! Thanks I'm looking forward to them!
dmaxx
- Apr 5, 2006
- sw Michigan
- 2014 Apex XTX, 2012 Apex SE, 2000 Vmax 700, 2000 AC Z-370, fast
- White Pigeon, MI
I just installed a used plug & play on my Attak and instant HOT with the adjusters turned off! Did not come with an on/off switch so it will be warm all the time. I hope it does not burn up as the sled smelled a little warm when I put it away, but I had changed the oil and other things so that was probably the warm smell. Last year I froze.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
there is no off anymore when you have yamaheaters on the off setting on the display is full blast on high as they will go then when you click up on the bars for the stock settings it starts at low and goes up from there I only used the 0 setting full high when the seld was warming up in the morn and then set at two to 3 bars the rest of the day.
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
I added an off on switch like the originals , Spring riding hands are always too hot.
Prefer to shut them off when not needed !
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
dmaxx said:I just installed a used plug & play on my Attak and instant HOT with the adjusters turned off! Did not come with an on/off switch so it will be warm all the time. I hope it does not burn up as the sled smelled a little warm when I put it away, but I had changed the oil and other things so that was probably the warm smell. Last year I froze.
Yes, you'll have to leave the warmers on the lowest setting or 1 bar as a an "Off" position. You bump the warmers to the factory off when you start out riding and then scroll back to a factory setting once they get warm. This is for the Plug & Play version WITHOUT Boost. I like to ride with as thin a glove as possible so the low setting in the late season doesn't bother me at all. If you think you'll want an off switch, get in touch with Rock, he'll take care of you.
- 14K
