Yamcharger Clutching: Dalton Weights
jaydaniels
Bedford NS Canada
Canada
2017 Sidewinder RTX
Is anyone using Dalton Clutch Weights with their Yamcharger. I have a Proline Clutch Kit that uses the Dalton DPYR 62 weights that I used with my stock sled. I was hoping to use these weights but add some heavier rivets as I'm over revving now. Pulling about 11000 rpm.
You need to add at least 3 gram to each weight arm to get it Down to 10700.
Ok thanks. I have the hollow alum rivet on the inside. I'll change it over to a steel. How are these rivets installed. Do you just push them in place.
