justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
The bolts are fine, the torque spec is not. Lessen the torque and bolts will be fine. I have gone 96 inch pds since my first winder and ive had 3 sleds since that one with a grand total of 16,000+ miles. Zero leaks or issues on any of the sleds and always used the original bolts. Any yes make sure bolts and holes are clean. Any lubrication on the bolts will reduce friction and cause you to overtorque the bolts.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Are you guys putting blue loctite on the cover bolts?
justinator
- Mar 25, 2007
- Maine
Ive never used loctite on the cover bolts.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Me eitherIve never used loctite on the cover bolts.
Turboflash
- Mar 18, 2019
- Southern MN
Me either, and I've never discovered any loose. Must have had dozens of cases apart, never any loose screws.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I still use it.
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
You need this kit or one like it to fix your chain case. Use a punch to gently make a centered mark on the broken bolt, then hold the correct size guide with a vice grip and drilling with a side drill put a hole in the broken bolt. Then insert the correct extractor, tapping it in gently with a hammer. The collar fits over the guide and you back it out with a wrench. Should come right out.
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
Now is the time to get rid of the torx screws and put in some 10.9 bolts. Makes life way easier to remove.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I did that the first time I changed the gear lube.Now is the time to get rid of the torx screws and put in some 10.9 bolts. Makes life way easier to remove.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Me too. I don't use loctite on them and don't over tighten them either.
When I first saw the Torx on the case I thought there are crap and should be replaced with Allen Head screws, but after using them for years its a non issue using the factory Torx screws.
Doc Harley
- Oct 17, 2016
- Here & there
Yep ....I torqued them to 130in
- 17K
